Enabling LDAP
In case you haven't noticed, LDAP has been introduced since Aperture Data Studio v2.0.11.
Go to Settings>Security to set up the LDAP properties.
Once this is set up, you can test the connection to the ldap server. A message will be shown to indicate whether the connection is successful or has failed.
Once the connection has been set up, you can then set up a user to use LDAP authentication.
Go to System>Users. When adding a new user or editing an existing user, you should be able to select LDAP and MS Active Directory server as an authentication mechanism and enter the LDAP ID.
Additional Notes:
- this does not affect connections using REST API/API token.
- account locking settings (maximum login attempts, account lockout time period) does not apply for users using LDAP.
Here's a useful commandline command for finding LDAP servers available on your domain:
nslookup -type=srv _ldap._tcp.%USERDNSDOMAIN%
Note that LDAPS has been deprecated and LDAP should be used, it will automatically negotiate a secure connection over port 389
- 471 Get involved
- 13 Support
- 269 Resources
- 218 Community categories
