Trash Bin?
WilliamPerrin
WilliamPerrin Member
edited October 2025 in Ideas board
What problem are you facing?
Deleting of batches often after a failed run. It's nerve racking not to delete a batch as some are very much needed batchs. We track data quality month on month, so accidentially deleting a needed month could happen.
Huge impact on the effectiveness of reports etc. If we delete something needed it's A) going to take a while to re-build the workflow / function and then run. Or B) it is not possible to get back. So something like a monthly dashboard that tracks progress will now just be missing a month.
Only possible fix would be to roll back Aperture?
A recycle bin - chaning the times for how long it holds onto things for. I.e. 1 week, so if you do click delete by mistake or change your mind. You have a week to re-instate it.
8
8 votes
  • Simms, Henry
    I like this idea and can definitely identify with the "nerve racking" feeling of permanently deleting a batch.
    However we should also consider scenarios where data retention policies mean data needs to be permanently deleted at a specific point in time and not retained for possible . So we probably want the equivalent of Shift + Delete in Windows if you don't want to use the recycle bin for your batch
  • Also like this idea! Another one I think might be potentially useful is when deleting spaces, there are more steps before execution. Like with environments when you have to type the environment name? And perhaps a short summary such as "Deleting this space will remove xx Workflows, xx Datasets etc. A recent example I've seen is the deletion of the wrong space, instead of an empty one with a similar name. Some additional confirmations may prevent the error before a recycle bin in required?
