Converting field to a date format
Wojciech Glowacki
Contributor
in General
Hi Again,
I have the below date column. I wanted to conver to to a proper date format like yyyy-mm-dd or dd-mm-yyyy. How can I do it? To Date or Convert to Date fucntions dont seem to be working :(
param inputString;
FormatDate(
CreateTimeStamp(
Substring([p:inputString], 1, 4),
Substring([p:inputString], 5, 6),
Substring([p:inputString], 7, 8),
0,
0,
0,
'dd-MM-yyyy'
)0 -
There's a pre-built Parse Date function available to download from the Function Library which does this in the same way, but with added flexibility of being able to define the input date format, and with some extra error handling when the date cannot be parsed:
Result with test input:
