Edit fields in Metadata entities when user/group is defined in field
Monasi Querzola, Alfredo
Monasi Querzola, Alfredo Experian Employee
edited February 20 in Ideas board
What problem are you facing?
When creating a new entity to register access to data elements some fields should be completed only by the owners of the entity. So some fields should only be editable by a specific user/group.
Final users approve or reject their own request if we allow them to fill that field (I know the approver could accept or reject the change but is not a clean solution)
Let the approver modify it manually, hoping the final user wont change it again.
When creating fields when editing enable available users to edit the field. This could work for any entity.
1 votes
Now available · Last Updated
