Search and replace of multiple values.
Alfredo Monasi
Alfredo Monasi Experian Employee
edited September 2025 in General
Hi everyone!,
I have a table with 2 columns, the first one is the string I should check inside a field, the other column is the value I should replace if its a match. How can I achieve this without creating a function with lots of steps for each string I need to search and replace.
ORIGINAL STRING
NEW STRINGTEXTO NUEVO
FIS|
FISICA|
LITERAT|
LITERATURA|
ABODADO
ABOGADO
ABODAGA
ABOGADO
ABOGADA
ABOGADO
ABOGADA
ABOGADO
ABOGADO-
ABOGADO
ABOGADO (A)
ABOGADO
ABOGADO(A)
ABOGADO
ABOGADOA)
ABOGADO
AGOGADO
ABOGADO
BACHILLER EN ADMINISTRACION HOTELERA Y DE TURISMO ADMINISTRACION HOTELERA Y DE TURISMO
BACHILLER EN ADMINISTRACION TURISTICO -
BACHILLER EN CIENCIAS ADMINISTRATIVAS|
BACHILLER EN ADMINISTRACION|
BACHILLER EN CIENCIAS CONTABLES Y FINANCIERAS|
BACHILLER EN CONTABILIDAD|
BACHILLER EN CIENCIAS DE INDUSTRIAS ALIMENTARIAS"
BACHILLER EN CIENCIAS DE INDUSTRIA ALIMENTARIA
BACHILLER EN CIENCIAS INDUSTRIAS ALIMENTARIAS
BACHILLER EN CIENCIAS INGENIERIA
BACHILLER EN CIENCIAS DE LA INGENIERIA
BACHILLER EN CIENCIAS SOCIAL
BACHILLER EN CIENCIA SOCIAL
BACHILLER EN CIENCIAS SOCIALES:
BACHILLER EN CIENCIAS: FORESTALES
BACHILLER EN CIENCIAS FORESTALES
Cheers,
Alfredo
  • Will these be the only values within the field, or are you looking inside say a comments filed? If it's the first one, I would just do a simple lookup using the table you have here as a lookup table. At least that way you stay flexible and can add more values later.
    If it's the second scenario (within comments type field), then I'm not sure top of my head. Maybe some expression replacement?
  • Alfredo Monasi
    Hi James,
    In this case I need to look inside a whole string for the specific pattern and replace it.
    Example:
    I have a field, for example ABCD1EFG. Then I have a table with 2 columns ToFind, To Replace
    ToFind
    ToReplace
    X
    Y
    so in the example would replace to ABCDXEFG
     If its ABC1DEF2GH should be replace as ABCXDEFYGH
     Cheers,
    Alfredo
  • James T Sidebotham
    Still use the lookup table, but use the function "Replace Matches"? I tried and seems to work within a comments field (space separated values before and after) with your original strings
    edited October 2025
  • Alfredo Monasi
    Thanks, it worked when is a whole word to replace with spaces. For other case inside a string I had to use a replace.
