Search and replace of multiple values.
Hi everyone!,
I have a table with 2 columns, the first one is the string I should check inside a field, the other column is the value I should replace if its a match. How can I achieve this without creating a function with lots of steps for each string I need to search and replace.
ORIGINAL STRING | NEW STRINGTEXTO NUEVO |
FIS| | FISICA| |
LITERAT| | LITERATURA| |
ABODADO | ABOGADO |
ABODAGA | ABOGADO |
ABOGADA | ABOGADO |
ABOGADA | ABOGADO |
ABOGADO- | ABOGADO |
ABOGADO (A) | ABOGADO |
ABOGADO(A) | ABOGADO |
ABOGADOA) | ABOGADO |
AGOGADO | ABOGADO |
BACHILLER EN ADMINISTRACION HOTELERA Y DE TURISMO ADMINISTRACION HOTELERA Y DE TURISMO | BACHILLER EN ADMINISTRACION HOTELERA Y DE TURISMO |
BACHILLER EN ADMINISTRACION TURISTICO - | BACHILLER EN ADMINISTRACION TURISTICO |
BACHILLER EN CIENCIAS ADMINISTRATIVAS| | BACHILLER EN ADMINISTRACION| |
BACHILLER EN CIENCIAS CONTABLES Y FINANCIERAS| | BACHILLER EN CONTABILIDAD| |
BACHILLER EN CIENCIAS DE INDUSTRIAS ALIMENTARIAS" | BACHILLER EN CIENCIAS DE INDUSTRIA ALIMENTARIA |
BACHILLER EN CIENCIAS INDUSTRIAS ALIMENTARIAS | BACHILLER EN CIENCIAS DE INDUSTRIAS ALIMENTARIAS |
BACHILLER EN CIENCIAS INGENIERIA | BACHILLER EN CIENCIAS DE LA INGENIERIA |
BACHILLER EN CIENCIAS SOCIAL | BACHILLER EN CIENCIA SOCIAL |
BACHILLER EN CIENCIAS SOCIALES: | BACHILLER EN CIENCIA SOCIAL |
BACHILLER EN CIENCIAS: FORESTALES | BACHILLER EN CIENCIAS FORESTALES |
Cheers,
Alfredo
Will these be the only values within the field, or are you looking inside say a comments filed? If it's the first one, I would just do a simple lookup using the table you have here as a lookup table. At least that way you stay flexible and can add more values later.
If it's the second scenario (within comments type field), then I'm not sure top of my head. Maybe some expression replacement?
Hi James,
In this case I need to look inside a whole string for the specific pattern and replace it.
Example:
I have a field, for example ABCD1EFG. Then I have a table with 2 columns ToFind, To Replace
ToFind
ToReplace
X
Y
so in the example would replace to ABCDXEFG
If its ABC1DEF2GH should be replace as ABCXDEFYGH
Cheers,
Alfredo
Still use the lookup table, but use the function "Replace Matches"? I tried and seems to work within a comments field (space separated values before and after) with your original strings
Thanks, it worked when is a whole word to replace with spaces. For other case inside a string I had to use a replace.
