Is there an easy way to do this partitioning?
I have seen previous posts on partitioning, and use that technique regularly. However, my need this time is slightly different. I have groupings of duplicates, but I would like to count incrementally when I come across a new identifier. I actually have this working now, but it took some Aperture kung-fu, so wondering if anyone has a simple way to do this.
The column I am focusing on to create is ID_NUM, I only want it to increment within the GROUP when a new IDENTIFIER is found, otherwise keep the existing ID_NUM. (ID_TOT shows how many unique IDs there are in the group.)
GROUP | IDENTIFIER | ID_TOT | ID_NUM |
AAAA | 12345 | 4 | 1 |
AAAA | 99999 | 4 | 2 |
AAAA | 54321 | 4 | 3 |
AAAA | 11111 | 4 | 4 |
BBBB | 90210 | 3 | 1 |
BBBB | 77777 | 3 | 2 |
BBBB | 13579 | 3 | 3 |
Take a look at this discussion:
https://community.experianaperture.io/discussion/837/
If that does not help then might useful to share more detail on how you approached and where you'd like it to be simpler
Thanks Josh, I had not seen that discussion in my forum search. The two that I used for help were:
The steps that I did were:
- Create a new column "Sort-row" from Row number (to be used by sort later to preserve the order)
- Group on: "Group", "Identifier" and aggregate on first populated value of "Sort-row"
- Sort the result (7 rows) by "Sort-row"
- Add new column "Row#2" from Row number
- Use a Lookup to get the row number where the partition (Group) starts
- Calculate the row increments (Part-row-incr) within the partition (Add(Subtract([c:ROW#2], [c:PART-ROW-START]),1))
- Do a Final lookup using the original data (11 rows) to the 7 rows from step 6. Lookup type=First, Return Column= "part-row-incr" where group=group and identifier=identifier
Looking at the thread you provided, I don't think I could do this much simpler. I did however have another method of creating a key of "Group+Identifier" and using Harmonize Duplicates rather than the grouping from step 2 above. Both work fine, I just don't know which method would be more efficient with 100,000s of duplicates and groupings - I haven't tested that yet. Any thoughts on that?
@Josh Boxer - any thoughts on the Harmonize vs Grouping method?
Also, if Aperture had a step similar to this mockup, I would be very happy!! It would add in 2 columns for Count and Row based on the column names/requirements I gave above. (I am sure adding other functions as well, such as average, sum etc would be useful).
Many moons ago i did write a partition custom step, so i think it should be possible to do within the SDK.
I'm not really sure of the status of this step and whether it was maintained for later versions though.
That's great Ian!! Seems like a native step would be used by others.
