Group Step > Being able to select and right click view multiple rows in groups
Tieu Lu
Tieu Lu Experian Employee
What problem are you facing?
When the Group step is used, we can only view rows in group on one value.
Feedback received of this not being user friendly and having to exit the screen to be able to get to the multiple filtered values.
Cannot look at multiple values within the group step so a user would need to exit this step and user other steps such as filter, split, lookup etc to get to the desired results.
Allow for multiple select and view rows in groups instead of only being able to look at rows within one group.
5
5 votes
Now available · Last Updated
Released in v2.15.14
