How to add Retention and Confidentially Classifications to Datasets uploaded to ADS
Hello Data Enthusiasts,
I'm currently facing a bit of challenge and seeking some guidance from the community.
I am looking to add Retention and Confidentiality Classifications to each field of Data during the Ingestion of data onto ADS. I'm looking to ensure that we're keeping the data for the appropriate length of time and that sensitive information is adequately protected by classifying the fields.
I've been digging through Forum posts and documentation and cannot find any clear instructions on how to implement this. One idea is to Tag the columns during the Annotation stage for example add a tag like "7 Year Retention" and "Highly Confidential (PII)".
I hope to get some advice if anyone has tackled similar challenge before. If you could share your insights on how to go about adding these Classifications and any tips or best practice ideas would also be greatly appreciated.
Thank you in Advance.
Hi Van
In terms of retention, in the coming weeks a new feature will allow you to set a number of days before data is automatically deleted.
Data tags can automatically identify sensitive data. Once a column has been marked as sensitive users are made aware before they share that data:
Finally the ability to manually tag objects like Datasets with specific labels will be possible in coming months using Object tags. If you would like to get early access or see a demo reach out to you Experian contact
- 485 Get involved
