Low Disk Space issue.
hussain syed
hussain syed Member
edited December 2023 in Administration
We have the disk space issue once more for our data drive. We changed the index expiry settings to 8 days, previously it was 15 days, last time we resolved this.
There is still huge temp folder, this is to ask you what can be removed from this folder.
1,4 TB is temp, can we remove dump***.dat files in temp folders after stopping the service? or it will have affects elsewhere? can we just remove the folders older than 8 days from this location D:\ApertureDataStudio\data\resource\temp\temp
Br, HS
