Low Disk Space issue.
We have the disk space issue once more for our data drive. We changed the index expiry settings to 8 days, previously it was 15 days, last time we resolved this.
There is still huge temp folder, this is to ask you what can be removed from this folder.
1,4 TB is temp, can we remove dump***.dat files in temp folders after stopping the service? or it will have affects elsewhere? can we just remove the folders older than 8 days from this location D:\ApertureDataStudio\data\resource\temp\temp
Br, HS
@Ian Hayden , please check, I have also sent you email for the same.
@Henry Simms , if someone else can have a look on this.
@HussainSyed I've replied to your email.
For reference, if you stop the server you can remove anything in the temp directory without any side-effects.
Regards,
Ian
thanks, yes I just checked your email.
- 491 Get involved
- 258 Resources
