Profiling multiple dataset
If it is an existing Workflow then you might need to unselect the specific columns to see the 'All columns' radio button.
Once you select All you can run the workflow with a different source each time without having to remap the columns. You might write the results to a multi-batch snapshot for example
Thanks @Josh Boxer
I have created one WF where I am passing the Datasets at run time , everytime a new dataset which is different in format than the previous one. In the WDF I am using the Profile step (all columns) and the profile result I am storing in Multibatch Snapshot. This way I am getting successful Profiling results in the Sanpshot. But one prob I am facing I am unable to show the Table Name only Column Name I can See there. If I am choosing the Metadata from the Profile Step then the WF is getting Failed
Thanks Mahulima let us look into it
This should now be resolved, so the Dataset name can be included in the Snapshot
