Can we add a hyperlink to the e-mail notification?
Vera Osvath
Vera Osvath Member
Hi!
Is it possible to add a hyperlink to the e-mail notification? It would be a nice feature to be able to add a URL or a direct link to the export folder where the exported files are located.
Many thanks!
Vera
  • Roden, Danny
    Roden, Danny Administrator
    Hi @Vera O,
    Thanks for your post. Short answer is that yes you can add a URL or a direct link to the export folder in your email notifications from Data Studio.
    When you're setting up your notifications/automations you can use the '@' sign to link to the workflowURL dynamically, but you can also put your own links in too, for example:
    Hope this helps!
    Danny
