Can we add a hyperlink to the e-mail notification?
Hi @Vera O,
Thanks for your post. Short answer is that yes you can add a URL or a direct link to the export folder in your email notifications from Data Studio.
When you're setting up your notifications/automations you can use the '@' sign to link to the workflowURL dynamically, but you can also put your own links in too, for example:
Hope this helps!
Danny
Hi Danny!
Thanks for your answer - yes the workflow URL I was able to add but when I'm adding the path to the export folder this is not appearing as a hyperlink in the e-mail but as plain text.
The URLs (starting with https) are fine, it appears as a link.
Many thanks!
Vera
Ah I see, right you are. I'll get this raised with our product team. Thanks Vera
Thanks Danny!
Unsure if this will work in all cases (see the part about security) will need testing
- 485 Get involved
