Adding datasets from database views
Marco_13112001
I'm currently uploading datasets in Aperture from a SQL database, a total of 15 tables were ingested with no issues but it seems that the process does not work for views and no error message is raised.
Are there any extra steps to enable the ingestion of database views by Aperture?
Many thanks in anticipation
Best regards,
Marco
    Hi Marco
    If you do not see any Views in the list (but want to), then you need to update the settings of the External system. Under advanced settings there is an option:
