Find Duplicates Blocking Keys and Rules in v2
If you have the license for Find Duplicates Fuzzy matching then you could use this functionality to match records based on fuzzy matches. This needs blocking keys and Find Duplicates rules
I noticed that in V2 that the Blocking Keys and Rules are now combined and accessible through Step Settings however I also noticed that there do not seem to be any default blocking keys and rules anymore.
Is there an easy way to set up the default blocking keys and rules from some standard predelivered examples?
@Clinton Jones These ship with the product. If you go into the installation folder, usually
c:\program files\experian\aperture data studio x.x.x
, you will find the detaults in thematchDefaults
folder. The files are named {Country}_{Scenario}_Default.{JSON/EXPR}Scenarios are one of:
- Household: Looks for people with the same last name at the same address (uses address and surname information)
- Individual: Looks for individuals, using Name and Address
JSON files are the blocking keys, since they follow the json specification.
EXPR are the custom Find Duplicates match rules. If you want to make it easier to read these expr files, you can use the language addon for Notepad++
5
I am facing the following error on Find Duplicates:
ERROR 2022-03-18 16:57:42,745 [http-nio-8080-exec-2] com.experian.match.rest.api.service.license.LicenseManagerOnPrem:validateLicense(91): Find Duplicates is unlicensed
Also my server where I have aperture data studio installed cannot connect to Find Duplicates ..
erro on remote server where ASD is installed:
Find duplicatesCan't connectN/AServer location: Remote (http://172.21.169.239:8080/match-rest-ap
i-2.6.9/)
Please help if you think I have missed some step.
Hi @HussainSyed it sounds like you are not explicitly licensed for the Find Duplicates functionality, is that something you particularly want/need and have you used it/had it before ?
@Katya Jermolina you may have some additional insight here based on work you have done with the client?
@Clinton Jones Hi, we have the licensed product we are just trying to use it on remote server.
@Henry Simms is already in contact with me to come up with the solution.
Hope this issue can be closed soon.
@Katya Jermolina please comment if you are in contact with Henry on this issue already.
@HussainSyed please CC me in the latest email chain and I will pick this up. As far as I am aware Find Duplicates was licensed as of last Thursday, since we were able to run jobs.
ok,
@Katya Jermolina I have added you in the latest email thread. Please let us know. thanks
@Katya Jermolina license updated successfully, but the main purpose of this was to get remote access, which is still not happening, please assist. if you can.
@Katya Jermolina My Question is, I should be able to access FD workbench and swagger UI from my own machine as well ?
As Aperture Data Studio is accessible everywhere. @Katya Jermolina
"You can access the Swagger-UI at http://<server>/api/docs/index.html"
FD Workbench
"If you have trouble accessing the Find duplicates workbench, please check that the service is installed and running."
both are running fine, and are accessible on our production server.
maybe my question was a bit confusion when I asked about remote access.
they are remotely accessible to production server..
swagger UI, FD Workbench.
My Q is, is there a way to make them accessible from any machine, as dev team using aperture data studio from their machines,
although last evening from experian team we are advised to use workbench only through production server and not expose production data to any other machine.
Just a query.
Hope you understood what I was asking.
