Importing DataSets - Filtering Data
Rachael
Rachael Member
I was wondering if there is currently anyway of limiting/filtering out data from an underlying table before importing it as a dataset? I have a number of transactional tables that I want to bring in to Aperture, however it would be great if I could limit the date range of the transactions before importing the table itself is upwards of 6 billion rows.
If there is no way of currently doing this, is it something that can be considered for a future release?
Thanks!
Rachael
  • Hi Clinton,
    Thanks - that's great news this is something which is being looked in to. The underlying tables have approximately 15-20 million records and it's connecting to a SQL database
    Rachael
  • Simms, Henry
    Hi @Rachael , just letting you know that you can now specify a SQL query when loading data from a Database: https://docs.experianaperture.io/data-quality/aperture-data-studio-v2/get-started/configure-external-systems/#loaddatausingasqlquery
    This will allow you to filter on load, as well as pushing additional processing like grouping or joining down to the data source system.
    Available from V2 5.6 onwards: https://community.experianaperture.io/discussion/760/
