Chart - Configuring range for X-axis
Van Sung Phan
Van Sung Phan Member
edited August 20 in General
Hi all, I have the below dataset used as a source for a timelapse chart. Data set and chart below.
Now, I want to pivot the tables and group by Year, but when I do that, the X-Axis shows categories not related to that year and I want t to show only the related categories in the X-Axis.
Is there a way, Without having to use a different dataset, to remove those unwanted highlighted categories from the X-Axis?
    Hello
    Yes the filter is being applied to the data and not the axis. This is specific to way the charts plot dates, so that if you have a point (month in this case) in the series missing from your data then it will show clearly that it is missing rather than a smooth line.
    If you click and drag on the chart then it will zoom in to show only the x-axis area you selected.
    You could group by your Year column if this helps to show the distinction with different colors:
    https://docs.experianaperture.io/data-quality/aperture-data-studio/objects/charts/
    Alternatively yes you would need to clone the Chart/step and apply the filter before the chart step
