Challenge 3 Solutions
Roden, Danny
Roden, Danny Administrator
edited June 2024 in Solutions
  • Roden, Danny
    edited October 2020
    The approach I've taken with this challenge is summarised below.
    First, to structure the data into a consistent (and valid) date format, I built a reusable function which used the 'substring' function to take the various different bits of the input and then feed that into a 'Create date/timestamp' function. After initially applying this to my data I noticed some errors present on my results (due to the fact that I hadn't taken into account values that aren't a valid date at all - e.g. '0'). So I added an 'If then else' function to check whether the input value appeared valid or not (based on length). See here for a preview of the STRING TO DATE CONVERSION FUNCTION that I ended up with.
    Next, after converting the data, I added a Validate Step to my workflow with rules for each of the tests in the challenge outline. The summary of my logic is below:
    (a) I built another reusable function (Is not a future date) which is a simple 'Less Than' function referencing the 'current date/time (dynamic)' function. You can see a preview of it here. I then applied this to all 3x fields.
    (b) the 'Start Date - is before Close Date' function was built with a simple 'Less Than' function (see here)
    (c) and the 'DOB - in valid range' test was built using the 'Get Age' function, which I fed into a 'In Valid Range' function (see here for a preview of this function)
    Finally, I prepared an output taking data from the 'Show all rows' output of the Validate step, which filtered on just records failing any rules. I then adjusted the columns for visual presentation and found 459x records failing one or more tests. To see my final output, please check out this final screenshot (and below for the .dmx package for the solution itself).
  • Sean Leoszko
    Sean Leoszko Experian Contributor
    The first part to solve was the formatting of dates, initially I tried using math to figure out when to add a delimiter between the time periods of the date, see below:
    User: "image.png"
    Though it worked, I thought of another way that was a bit more streamlined. This also converted zero's to null but depending on the use case could be converted easily to another value. This was created as a custom function so it can be used across all three columns in a workflow
    User: "image.png"
    After this, I created a workflow to apply the custom function across the three date fields and validate the data:
    The sirst Transform aims at applying the formatting of date fields created above:
    The second Transform is to validate the three rules:
    -The date (for all columns) is not a future date
    -Close Dates should never be before Start Dates (added a clause to allow for null Close Dates)
    -The ages of those whose date of births are present should be between 18 and 95 years old.
    I added all these rules as new columns in a Transformation Step. I then use a validation step to validate if these three columns are true. Another way would be to include these transformations into the Validation step itself.
    I couldnt find the actual challenge 3 sample file so I created my own, so the results will vary. Below are the failing rows:
    Also, could not upload my dmx as it says file extension is not allowed
  • Sean Leoszko
    The first part to solve was the formatting of dates:
    User: "image.png"
    I converted zero's to null but depending on the use case could be converted easily to another character or value.
    After the custom function of convert these dates was created and published. The next stage was to create the workflow
    Transform 1 - Applies the Format Date function to all three date fields:
    Transform 2 - Creates the Rules for Validation - (This could have been created in the validation step to streamline it further)
    Rule 1-The date (for all columns) is not a future date
    Rule 2-Close Dates should never be before Start Dates
    Rule 3-The ages of those whose date of births are present should be between 18 and 95 years old.
    Added the Validation step at the end to show all the failed rows. The validation step only checks if these three fields are true.
    Below are the failed results from the validation step (I could not find the Challenge 3 Data so results will vary):
    Tried to upload my dmx file but I received the follow message:
    Had to zip the file in order to upload it.
  • Ebru Erozturk
    Ebru Erozturk Experian Employee
    My approach was;
    • Checked the lengths from profile results and seems like we have 0’s as date for Close Date and Dob
    • In the function (Convert To Date_Custom);
    First, created 'LengthOfDate' variable from of the original date.
    Secondly, created 'CalcDate' variable as;, if length is 8, used as is, if length is 7 concatenated with a leading 0, if length is not 7 or 8, nullified the information.
    Then, used 'Create date/time stamp' to create a date with the CalcDate variable that I've created, using substring to be able to get day/month/year information.
    • Added a transform step to be able to convert dates to actual dates, to be able to see the originals & calculated ones, I've created 3 additional columns names are ending with _C:
    • Add another transform step to be able to define the flags for validation rules:
    For LessThanTodayFlag; created CurrentDatetime variable and used it to check for all of the dates:
    For CorrectCloseDayFlag; checked if close date is greater than or equal to start date & if close date is null or empty:
    For AgeIn18-95RangeFlag; get the age from the calculated dob and checked if it's between 18-95:
    And in the end, I have these 3 additional columns which I used for validate step:
    • Added Validate step to check the supplied validation rules
    • Took a snapshot using failing rows in the end and created a view:
    • Didn't use the validation results, instead used the flags that I've created so we don't need to use filter. Adding the dmxd file as well:
