Add Object Tags to Jobs Log
Samuel Poke
Samuel Poke Experian Employee
What problem are you facing?
I have some fairly complex automations & scheduled jobs running. This means my job log quickly fills up, making it difficult to navigate.
Examples
It would be helpful if I could filter out some of these jobs so I can more clearly monitor the important ones.
More time spent filtering/scanning the jobs log than I'd like.
I can rename each important job with a prefix/suffix, e.g., CORE_DataQualityJob, and then use it as a search term in the filter list.
I think the simplest way to do this would be to expand the existing Object Tag feature to the Job log.
I can then easily tag my important/core workflows and use them as filters in the Jobs screen.
Object Tags
4
4 votes
  • Would be nice if the jobs inherited the object tags from the workflow?
    Also, having the filter/search criteria be persistent would be great. If I go into a job, I have to re-do any filters I had.
  • Samuel Poke
    That's a good point, James - I was also thinking it could inherit the tag from the workflow, but it's got me thinking; the workflow could be linked to other objects, e.g. Datasets, Automations or Views.
    It could also be helpful to inherit those tags.
