Support Needed: Workflow Migration Failing During Metadata Import
Hi Team,
We are seeing an issue while migrating an Aperture workflow from Pre-Prod to Prod. During metadata import into our shared space, the process fails with:
Could you please advise on this error? We have successfully completed migrations using the same approach in the past without any issues, so we're keen to understand what may have changed or if there are any additional checks we should perform. Your guidance would be greatly appreciated
    Is the 'Prod' destination installation using the same or newer version of Aperture Data Studio?
  • I’ve just checked and noticed that the Aperture Data Studio versions are different across the instances. Could this be the reason for the migration/import issue?
    Also, could you please confirm what the latest Aperture Data Studio version is?
    Latest version 3.4.5 https://community.experianaperture.io/categories/releases-and-downloads
    They can be different, but you cannot import into an older version than you exported from (you can import into a newer version)
