how to fix the workflow is not an executable state error message.
Rajeshkumar Kennedy
Member
in Support
Hello
There are some useful comments in this article that might help
If you cannot resolve the issue then the best option is to create a .dmx file with the workflow and create a Support ticket so it can be investigated for you, which is also mentioned in this discussion.
