can't able to create the data studio containers.but we can able to create the find duplicates and fi
can't able to create the data studio containers.but we can able to create the find duplicates and find duplicates workbench. we are using docker containers to run the application.aws ec2 ubuntu
    The ZIP files have containers for Aperture Data Studio and separate for Find duplicates. It sounds like you are not able to use the Data Studio container, but you have not given any detail on why it is not working for you
    https://docs.experianaperture.io/data-quality/aperture-data-studio/installation/deploy-linux-container/
  • Hi, thank you for your comment. when we try to create the containers, we are facing the space issue. so we increased the volume size to fix the space issue. after increased the volume , we ran the docker compose up command to start the containers.after this find duplicates and find duplicates workbench containers only created.data studio container didn't create. we have checked the container logs, we got these errors"
    • “Could not create directory /ApertureDataStudio/data/log”
    • “Cannot create directory ‘/ApertureDataStudio/smartharmonize’”
    • “FileNotFoundException: /ApertureDataStudio/data/database.lck (No such file or directory)”
