Group Data by Year
Wojciech Glowacki
Member
in General
Hello,
in one of my datasets I have a date column. Is there a way I can group this and count by Year only? I know I can group them by the whole date but is there a way to do it by year. Thanks!
I know probably I can do it by first transform that data and just leave the first 4 digits, save it and then group and count, but we got some questions that people would like to do it during profiling of the table.
You are correct that would need to add a new column using a Transform step and the Substring Function to create a Year column that can be grouped on
There's also a Parse Date function which could help here:
Once the value is a "Date" datatype, you can use the Get Years function. You can Profile the resulting output in a Workflow
