v2 to v3
HussainSyed
HussainSyed Member
edited July 30 in Administration
do i need to do v 3.0.0 when i m going from ads v2 to v3, or i can go straigh tto latest ads v3.0.8? br, hs
    You can always upgrade to the latest version of Aperture.
    Before upgrading from v2.X.X to v3.X.X you need to enable Cloud Licensing
  • KatriM
    KatriM Member
    edited July 30
    Thanks for this information
    However, what does this mean? Is this cloud licensing mandatory now only for having the data governance modules or some other modules for which the cloud licensing is needed now?
    Are we able to proceed with the upgrade now with legacy license key and then take that cloud licensing into use later (in near future)?
    Cloud license management FAQ
    1. Is cloud licensing mandatory or can I continue using my legacy license key?
      a. for some customers yes it is already mandatory, for others they can continue using their license key for now, but it will become mandatory for all customers in the near future, so upgrading is strongly recommended.
  • Ivan Ng
    Ivan Ng Administrator
    edited July 30
    Hi Katri,
    Cloud license is mandatory in order to use version 3.0 onwards. Upgrading to a cloud license will encompass all modules that you are currently licensed for. This would also mean that you can't just use cloud license for eg the governance module while having the rest on the legacy key.
    For ease of upgrade, we recommend upgrading to cloud license in your current version of Data Studio before upgrading to v3.08.
    Hope this explains. Let me know if you have any further questions. Thanks..
    Best Regards,
    Ivan Ng
