Combine Filter/Split step
I'm raising this on here as it's come up a few times with various users and I want to see what others' think of the idea to essentially combine the filter and split steps (which perform the same action, with the only difference being the split step allows users to view unfiltered results):
vs
I myself have found on several occassions where I'm interactively exploring data and then adding this to the workflow design, I've later needed access to the unfiltered rows (as well as the filtered selection).
I think it'd be great if we could either combine these steps so that effectively the unfiltered results are always available or perhaps provide a toggle button (similar to how the 'and' function can toggle to an 'or' function on the function editor canvas) so as to provide the same effort (and avoid the need to respecify the filter logic when replacing a filter step with a split step.
Keen to here others' thoughts!
Cheers,
Danny
11 votes
In development · Last Updated
  • Hi Danny - I would definitely like it if we could view the unselected records from a Filter step. I'd be happy for the Filter and Split steps to be combined so this option is always available, rather than having to use a toggle.
    I'm often creating filter steps by using the quick filter in Explore mode (right-click → Keep / Remove) and then using "Add To Workflow". I'm often frustrated that this gives me a Filter rather than a Split. It would be great to be able to easily convert between the two, or to have a Split step created instead when applying quick filtering back to the workflow.
  • Gets my vote
  • Ian Buckle
    The introduction of copying scripts had somewhat alleviated this for me, however I do agree often require the need to convert filter to split.
  • I totally support joining.
    I have started to use only the Split step due to I have several times used first Filter, and then realizing later the need to study as well unfiltered data.
