Determine the minimum numeric value when column contains null/string values
Fuks, Emilia (GB)
Fuks, Emilia (GB) Contributor
edited June 2025 in Ideas board
What problem are you facing?
The "minimum" aggregate returns null() as the minimum if at least one of the values in a column are empty.
This impacts data quality and returns incorrect results for aggregates when dealing with numeric values.
Still testing a workaround but currently trying to filter off null() values before the group step and then joining them back on.
Add a numeric minimum and a numeric maximum aggregate, which would ignore null() or invalid values and return the minimum/maximum numeric value.
7 votes
  • Simms, Henry
    edited June 2025
    Note - these new "Numeric minimum" and "Numeric Maximum" aggregates in the Group step should operate like the existing "numeric" aggregates like "Sum" and "Average" by automatically excluding / ignoring non-numeric values. The documentation describes this already
