What is the cause of an error message that says "4058: Unable to rollback" and how can it be fixed?
This error occurs on the Export workflow step.
Hi Sylvester, I assume you are trying to write to a database, which is returning that error. Please can you share more information on what you are trying to do as I dont think I have seen that message previously.
You can also reach out to our Support team with additional information: version of aperture you are using, version of the JDBC driver you are using, what you are trying to achieve, possibly export the workflow and share it etc.
https://docs.experianaperture.io/more/contact-us/0 -
Hi Josh, Thanks. The error occurs when exporting data via JDBC to sql database on Azure.
There is not much information on that error. Seems like it might be connection related. If you are still seeing the error then check (or ask your administrator to check) thenAperture Log file to see if there is more information about the error in there.
Thank you Josh
