Manually reviewing clusters of duplicate records (Stewardship)
Mirjam Schuke
Mirjam Schuke Administrator
edited March 17 in Ideas board
What problem are you facing?
As a Find duplicates user I want to be able to manually evaluate and change clusters of records where I think the rules have matched records incorrectly e.g. I've got a husband and wife in my data, both called M. Smith and they share the same postal address, email address and loyalty card number. They're not a duplicate so I need to be able to separate them into individual clusters.
The rules do a great job identifying duplicates in vast majority of my data, but there are certain clusters where a manual review and update would improve the results ensuring all of my matches are correct.
Adjusting the rules e.g. by making them stricter, I can influence a bit what records end up in one cluster but it's not always granular enough for very specific cases and can sometimes make overall results worse.
Allowing me to make manual adjustments, like merging and de-merging records and also to compare and and match multiple records.
3 votes
In development · Last Updated
  • Ian Buckle
    Ian Buckle Experian Contributor
    LWC use case is similar but for businesses matching, there are always edge cases they want to permanently prevent from matching that wont with rules alone.
  • Mirjam Schuke
    We're in the process of designing and developing this functionality. If you're interested in being involved to give feedback or participate in user testing please comment or drop me a message. @Ian Buckle I'll get in touch when we have something to demo.
