Ability to select specific last number of batches in charts
James T Sidebotham
Contributor
What problem are you facing?
For charts, if I only want to list the last N batches, I have to create a whole new process to create a new dataset.
Extra maintenance and resources
Use workflow to filter the main dataset by X last batches. Use that smaller dataset in the chart.
Charts options there would be a "Get Last X batches" from the data source if a multi-batch source was detected
I can see value in this for Views also.
