Charts - last 10 batches
Hi, if i wanted to create a chart that graphs data quality over time, but I only wanted to display the latest 10 batches from a dataset, what are my options for this? I was thinking that a workflow would use the original file as a source, and I would specify 10 batches, and that would output to a dataset (single batch only) - then chart would read from that smaller dataset. This workflow would just have to be run whenever the original dataset gets a new batch.
I was hoping in the Charts options there would be a "Get Last X batches" from the data source if a multi-batch source was detected.
Set the Dataset/Snapshot to delete older batches whenever a new batch(es) is added.
I want to keep all batches as part of audit trail, but only want last X (10, but could be 5 or 3) to show up on the chart to keep it from being too cluttered.
Maybe write to a second Snapshot, one for all batches and the new one limited to 10 or 5 or 3.
Note that charts in Aperture have the ability to click and drag to zoom into a specific area if you do have a cluttered chart
Thanks Josh, your solution is the one I was thinking of, just wish there was an easier option such as 'only select latest X batches'
I think this could probably be added as an option when creating a View or Chart if people would find it useful. You can add here and see if it get some support
