Email notification for job failure and success
Hi Team,
We need to set up batch alerting for both failure and success for the below email addresses on the CAIS production environment. But the jobs are not yet placed in the environment.
Could you please help us to set up the email notification for both job failure and success.
Regards
Uma Devi k
Hi Uma,
To accomplish this, navigate to Settings > Communication and enable the SMTP Email Protocol property.
Then create an automation and complete the information. Select the Enabled checkbox and select an event e.g. Workflow failed
Select the Filter icon to add a filter and select a workflow.
Select send email, in Action, and complete the relevant fields.
There is further information here:
Hope this helps!
- *The last screenshot shows Workflow completed, should be Workflow failed instead for this example
0 - *The last screenshot shows Workflow completed, should be Workflow failed instead for this example
