ssl cert update process.
has the process changed to update ssl cert on newer version?
previously i used to do this,
and hit save,
now i see this,
and does the section for public certificate needs to be empty?
you guidance will be really appreciated, as our cert is expiring in 1 month or so on our dev server.
Br,
HS
The ability to apply an SSL certificate via the UI was added in v2.12.9
Public certificates are for connecting Data Studio to 3rd-party applications. If this is not what you are doing then can ignore
Click the button 'Upload server certificate' then click the button 'Upload key file' (or drag the file into the dashed line box). Do the same clicking the 'Upload certificate file' button
We've extended the documentation to explain what the Server certificate and Public certificate settings are used for:
The Server certificate section in Settings > Communication is used to add a certificate to the Java keystore. The server certificate will be used by the server (Data Studio) to authenticate itself to clients (browsers, or API integrations).
The Public certificate section is used to add certificates to the Java truststore. While a keystore typically holds a certificate owned by the server (Data Studio) that identify it to clients, a truststore holds public certificates that allow other services to be trusted. Public certificates would be added to allow Data Studio, acting as the client, to set up successful SSL connections to other applications such as APIs or external data sources.
@josh
I still cannot find the steps that are needed to be performed from links you posted, as I explained the previous steps that we have in our documentation.
I need steps explained via UI.0 -
thanks josh, so it is almost same, just a little change in UI,
we will follow the same practice as we do. thanks for prompt response.0 -
thanks @Henry Simms , everything went perfectly fine and we have applied the new cert on our dev environment.
- 491 Get involved
- 258 Resources
