Copy dashboards between spaces
Is there a way I can copy dashboards, or their underlying charts between spaces.
I am creating numerous ADS Dashboards each in their own space but with the same layout. All will point to a different dataset (always structured the same). I thought about creating a master list of charts and sharing them, then just copying and repointing the copy to that spaces data, but can't do that with shared charts.
Hi Jasper
You can Clone a Dashboard within the same Space. A user (Consumer or Designer) will see Dashboards from all of the Spaces they have access to:
If you are using a recent version of Data Studio then you could create a template Space containing all of the Views, Charts and Dashboards required, then copy/clone the Space multiple times and edit each as required.
Alternatively you can Export and Sync these objects (Dashboards, Views, Charts) from one Space to another
Clever idea to use the template space and clone/copy it, that will save us plenty of rework, thank you Josh
