Upgrade Issue, Aperture data studio , Find Duplicates latest versions
Hi Ian,
Looks like after the recent upgrade we have an issue that experianmatch path got changed to the C drive automatically, meaning it did not following the existing configuration we have which were to be this onto D drive. And even after changing the path manually on Find Duplicates ini file, it still does not update the Experian match folders in D drive.
Our previous settings:
Virtual Machine Parameters=-Dlogging.config=log4j2.xml -Dspring.config.name=find_duplicates -Dmatch.database.path.windows="D:\ApertureDataStudio\data\experianmatch" -Dserver.port="8080" -Dmatch.maximum.cluster.size="500" -Dmatch.standardize.url=
but then after installation it changed to C:
"C:\ApertureDataStudio\data\experianmatch"
I even changed it back to D: , it does not make any difference.
please help us resolve this we don’t want to populate our C drive.
Br,
Hussain Syed
@Ian Hayden Please have a look on this one too, I sent you another email now.
@Henry Simms this is affecting our whole dev.
Hello
Please can you raise a case for this to ensure you receive timely support? They would likely want to know which version you upgraded from and to also if it is Windows or Linux. Thanks
@Josh Boxer we updated to the latest versions you have here for windows.
@Josh Boxer I already raised to support on Uk.support.qas@experian.com and kept @Ian Hayden in the mail chain.
Br,
HS
