ODATA: filtering the access to a dataset
Hello dear community,
Our use case is as follow:
We will have a big dataset and we would like to get access into it using Odata, but we are not interested in the hole dataset, only a small part.
Is it possible to apply a filter when we get access to a dataset using Odata
Thank you in advance
Hi Ali
It is not possible to filter operator when using OData, but I have added your vote to the request.
If you are loading the data into Excel or PowerBI then PowerQuery will let you apply filters before the dataset is loaded/refreshed.
- 491 Get involved
- 258 Resources
