Input source filename as export filename
Hi All!
Could you please let me know how can I automatically add the input source filename to the export filename in the workflow?
I can get the input filename with the metadata, but how can I add somehow as a parameter to make it the exported file's name?
Many thanks!
Kind regards,
Vera
Hi Josh,
I think I was able to find a simpler solution, added this to the notification:
The Input_filename parameter I added to the workflow.
So when the dataset is loaded this triggers the workflow and the input filename will be in the export filename.
Kind regards,
Vera
