Input source filename as export filename
Vera O
Vera O Member
Hi All!
Could you please let me know how can I automatically add the input source filename to the export filename in the workflow?
I can get the input filename with the metadata, but how can I add somehow as a parameter to make it the exported file's name?
Many thanks!
Kind regards,
Vera
  • Vera O
    Vera O Member
    Hi Josh,
    I think I was able to find a simpler solution, added this to the notification:
    The Input_filename parameter I added to the workflow.
    So when the dataset is loaded this triggers the workflow and the input filename will be in the export filename.
    Kind regards,
    Vera
