Refresh a dataset from REST WS
Hi dear community,
Is it possible to refresh a dataset data through REST web service ?
I know that we can:
1- upload a file into Aperture through REST
2- create a dataset data using the file key
But I can not see how to refresh an existing dataset data with a new uploaded file ,( I don't want to use delete function because it will broke my workflows using that initial dataset data)
Thanks a lot for you help
Ali
Hi Ali
Manually create a Workflow using Dataset A. In Source step select 'Can supply source when executed'
Using APIs, as you mention above, create Dataset B then run workflow with Dataset B
Optional delete Dataset B, repeat Dataset C etc.
An alternate option that might be easier than API in this case is to use a Dropzone folder to automatically update the Dataset and an Automation to run the Workflow whenever the Dataset is updated.
