Is there a scramble function?
James T Sidebotham
Is there a scramble function (much like there was in Pandora), as that feature was great for hiding PII but keeping the cardinality of values.
    edited June 2023 Answer ✓
    Having a look at what Pandora's scramble did, and specifically it retains the format of values (length, character type), as well as transforming values consistently:
    It does this by replacing alphabetic characters with other random alphabetic chars, numbers with other numbers, and retaining most common non-alphanum characters.
    Given this, the hash code function alone may not be quite the right thing, depending on the use-case, because it transforms values consistently but at the expense of format:
    If you want to retain the format, also using the Format pattern function may be useful:
    The format pattern is derived by replacing character types with a standard character (eg all alphabetic characters become A, all numeric chars become 9).
