Is there a scramble function?
Is there a scramble function (much like there was in Pandora), as that feature was great for hiding PII but keeping the cardinality of values.
Having a look at what Pandora's scramble did, and specifically it retains the format of values (length, character type), as well as transforming values consistently:
It does this by replacing alphabetic characters with other random alphabetic chars, numbers with other numbers, and retaining most common non-alphanum characters.
Given this, the hash code function alone may not be quite the right thing, depending on the use-case, because it transforms values consistently but at the expense of format:
If you want to retain the format, also using the Format pattern function may be useful:
The format pattern is derived by replacing character types with a standard character (eg all alphabetic characters become A, all numeric chars become 9).
Hi James
You can use the Hash Function to mask PII / sensitive values.
If you are using Data Tags on columns
Then Suggest Transformation will suggest it is applied:
- 491 Get involved
- 258 Resources
