Help with Blocking Keys for Phone Numbers not generating results
Hi all,
I'm trying to create two blocking keys for phone numbers, one that works off the first 5 digits, and one that works off the last 5 digits. I've tried several variations of this both in with other blocking keys and now on their own, and they are not generating any results, can anybody help with suggestions of where I am going wrong?
Here is the latest script that I'm using:
"description":"Phone_Area",
"countryCode":"GBR",
"elementSpecifications":[{
"elementType":"PHONE",
"elementGroups":["PHONE1","PHONE2"],
"algorithm":{
"name":"START_SUBSTRING",
"properties":{"LENGTH":5}},
"includeFromNChars":1
"description":"Phone_Local",
"algorithm":{
"name":"END_SUBSTRING",
For reference PHONE1 is a mobile field and PHONE2 is a Telephone field. I have also run this manually and know that there are blocks to be created from this.
Thanks all :)
Hi @BAmos
Just tested this, it looks like you need to lowecase "LENGTH" to "length" for both the Phone_Local and Phone_Area keys, eg:
"algorithm":{
"properties":{
"length":5
},With that change, I now see blocking keys being created as expected when using the workbench:
Note that the example phone numbers used here are randomly generated test data.
Thanks, Henry
Hi @BAmos
just to add to @Henry Simms answer above if you change your matching rules to have the following:
it will take into account the names of the Element Groups you have used changing the results from this:
to this:
