Error message when trying to define settings of a external system table
Marco_13112001
Member
We have connected one of our systems with Aperture, the connection is sucessfull and I can see 220 tables but when trying to go through the define seetings step I'm receiving the following error message.
[ApertureDataStudio][SQLServer JDBC Driver][SQLServer]Invalid object name 'table name'
Is that an error produce by a bad connection with the external system or something wrong with the source database?
Many thanks in advance for your help
Best regards,
Marco
Hi @Marco_13112001
The most common solution here is to check the "Force JDBC schema name" setting in the external system's configuration.
https://docs.experianaperture.io/data-quality/aperture-data-studio-v2/get-started/configure-external-systems/#microsoft-sql-server_invalidobjectname1
- 484 Get involved
