Validation - order of rules
Nigel Light
Nigel Light Contributor
Is it possible to arrange the sort order of rules (possibly by manipulating the Order number within a Validate step)?
Thanks Nige
    Hi Nigel
    If you click 'Edit script' then you can copy/paste to quickly re-order the rules (can also rename, edit description text and move between groups if required):
  • Nigel Light
    Thanks @Josh Boxer . I'll give it a go. Nige
