Validation - order of rules
Nigel Light
Contributor
Is it possible to arrange the sort order of rules (possibly by manipulating the Order number within a Validate step)?
Thanks Nige
Hi Nigel
If you click 'Edit script' then you can copy/paste to quickly re-order the rules (can also rename, edit description text and move between groups if required):
Thanks @Josh Boxer . I'll give it a go. Nige
