Joining to Validate Function, but keep Validation Formatting
Hi, I have a Validation step, it works perfectly. However, I want to append an additional column via join. When I apply the join the Validation functionality (i.e. status changing colour, drill down to see rules no long available).
Is there a way to join without losing that functionality. Or maybe some hack?
What I am trying to achieve is easier with pictures but unsure how to add them.
I have a validation step that does many tests on a single Field. I then run a further validation step on the results that returns a Pass if the record passes every test, or a fail if it fails a single test. That gives me the number of records that pass all tests. I then test the average pass rate across all rules, (i.e. so if a record passes two of three rules it gets a %_rules_passed value of 66%, I then find the average across all %_rules_passed). I want to join this value to the validation table without losing the validation table functionality.
Jasper I am unsure what you are trying to do, but you should now be able to add images if that helps explain
I do not think it is possible to amend the Validation rule result output and keep the interactivity.
I cannot think why the average of the pass rate would be useful and how you would use it? An example might be helpful
- 485 Get involved
