is it ok to delete the default environment
Rfaas
Rfaas Member
edited December 2023 in Administration
for a cleaner login experience for users, if we are never going to use the default environment, is it ok to delete the default environment? Thanks.
    Hi
    Once you type ' Default' (or the name of the Environment), click on the dialogue outside of the text box and as long as the value matches the Yes option will be enabled:
    edited January 2023
    Hi
    Yes an environment can be deleted, inc default, (by an Admin as long as you they are not in it). Having one environment will result in the dropdown on login page no longer being shown: https://community.experianaperture.io/discussion/709
    The Super Admin account ("We do not recommend using it for normal day to day activity") "can manage and access all Environments, so the 'Manage Environments' screen will always be shown when logging in as this user"
    https://docs.experianaperture.io/data-quality/aperture-data-studio-v2/set-up/create-groups-users-or-roles/#superadmin
  • I try to delete, logged on as internal administrator, I get the dialoge "Are you sure you want to permanently delete this Environment? This can't be undone", then it has a text box with a label: "Enter the name fo the Environment to continue:"
    with a Yes and No button below, and the Yes button is lowlighted disabled. Only the No button link is active.
    I enter "Default" and still I cannot enter "Yes" to delete it.
    The internal administrator account should have all the necessary rights, correct?
    I have verified that I am not logged into the default environment, but rather, the named environment we will be using.
