Java pid hprof crash files.
Facing the issue in our dev server for Aperture Data Studio and Find Duplicates.
In log I have found this at the same timestamp when I got the crash file in installation dir.
2022-12-14 05:20:12,255 ERROR c.e.m.a.MatchInstance [pool-157-thread-1] An unexpected error occurred when running Find Duplicates step against duplicate store 1918296f-8bed-4201-8a45-95b18d03bcf1.
javax.ws.rs.ProcessingException: java.net.SocketException: Software caused connection abort: recv failed
and later down few lines in log I have this.
2022-12-14 05:52:29,490 WARN i.m.c.i.p.PushMeterRegistry [logging-metrics-publisher] Unexpected exception thrown while publishing metrics for LoggingMeterRegistry
java.lang.OutOfMemoryError: Java heap space
' 1918296f-8bed-4201-8a45-95b18d03bcf1' where do I find this UID for duplicate store to know that this particular workflow is causing this issue every day, As I see everyday 30 GB java crash file, and service is not running anymore.
@Henry Simms @Ian Buckle @Josh Boxer
Kindly help.
Regards,
Hussain Syed
Hi Hussain
Please can you create a Support case for this issue so that we can help you to resolve?
https://docs.experianaperture.io/more/contact-support/
It would be helpful to know which version of Data Studio and Find Duplicates you are running? Approx how many records you are processing and the memory allocation of this environment.
Sure I will create the tkt.
