how to find Dataset & External Systems dependency
I tried with API to get the list where I can find the list of the Datasets along with the external systems it belongs to. But in the Dependon part I am only getting the List of the external systems on which any datasets are depending in the specific SPACE but not getting the info which Datasets are depending on those external systems.
Can you please help me with the info if it is possible to get with API or any other way?
Hi
Go to the External system and select Associations. It will show all Datasets across all Spaces:
https://docs.experianaperture.io/data-quality/aperture-data-studio-v2/get-started/associations/
@Josh Boxer If I have 60 + systems then how can I get those ? in this method I have to go manually to each and every systems to get the association. Is there a way with which we can automate? also in the suggested method how to get the export in csv, as I am not able to find any option for that.
The API List Datasets includes every Dataset and the details: Space, External system details etc.
@Josh Boxer hi josh, Can you please check once, the API response for Dataset I am getting I am getting the below Information I am getting SPACES but not external systems
@Josh Boxer Thank You!
- 470 Get involved
- 13 Support
- 272 Resources
- 218 Community categories
