Connecting to a database with a different schema
SpeedySteven
Member
Is there a setting that needs including to be able to pull data from a different schema from the same database? I keep getting an invalid object name error - I've attached the setup.
Hi @SpeedySteven
It looks like you'll just need to set the Force JDBC schema name setting in the external system's configuration - see https://docs.experianaperture.io/data-quality/aperture-data-studio-v2/get-started/configure-external-systems/#microsoft-sql-server_invalidobjectname1
Brilliant - thank you so much, I'm up and running
